Hello everybody!
I'm working with Visual Studio 2010 an can compile my project as a .dll and also debuggin is available. The testproject I have created works, due to the messegabox , which appears when I register the protk.dat.
Now I tried to create a button in the ribbon-menu and therefore I wrote the nesessary commands. Everything works until the command ProCmdDesignate creates an error which is:
PRO_TK_MSG_NOT_FOUND - One or more messages was not found in the message file
I have studied the other examples and theis .txt-files but anyway, I can not find the error!!!
Here is my code:
Code:
uiCmdCmdIdcmd_id;
ProError status;
ProFileName text_file;
int menuId;
static uiCmdAccessState TestAccessDefault(uiCmdAccessMode access_mode)
return (ACCESS_AVAILABLE);
}extern "C" int user_initialize(int argc, // Number of arguments
char *argv[],// Pro/E arguments
char *proe_vsn,// Pro/E version
char *build,// Pro/E build
wchar_t err_buff[]) // Error buffer
ProArrayAlloc (1, sizeof (ProUIMessageButton),
1, (ProArray*)&buttons);ProStringToWstring (text_file, "text.txt");
status = ProCmdActionAdd("Testfunktion", (uiCmdCmdActFn)Show_MsgBox, uiCmdPrioDefault, TestAccessDefault,
PRO_B_TRUE, PRO_B_TRUE, &cmd_id);status = ProCmdIconSet(cmd_id, "annotation_round");
status = ProCmdDesignate(cmd_id, "-AAAAAA", "-BBBBB", "CCCCCC", text_file);
return 0;
And the .txt-file:
Code:
-AAAAAA
AAAAAA
-BBBBB
BBBBB
CCCCCC
CCCCCC
I really hope anybody can do help me!!! I appreciate an hints in the right direction to solve my problem!!!
Thanks in advance!
Johannes
