Problems with Pro Mechanica Installation Wildfire 2.0 M050
vito_basile
Hi everybody,
I have a problem with my installation. I can't use my Pro/Mechanica Motion
module.
I installed Pro Engineer release Wildfire 2.0 M050 with all Pro/Mechanica
Module and Microsoft Visual C++ 6.0.
When I try to execute Pro Mechanica integrated mode
(APPLICATION_MECHANICA), the following message is displayed:
"Cannot find Mechanica installation. Some features will be disabled."
A new window (I attached a jpg) asks me which module I want to use:
STRUCTURE, THERMAL, MOTION.
If I choose "MOTION" the FEM MODE check-box is disabled and a new warning
message says:
"Mechanica is not available. Only FEM Mode is currently available."
Does anyone can help me?
Thanks in advance
Vito
Vito,
It sounds like the problem is that your Pro/Engineer installation does not yet know where to find Pro/Mechanica. You need to run the PTCSETUP program located in the Pro/Engineer folder again, and step through the configuration. Somewhere along that you will be asked where Pro/M is located. After PTCSETUP did its work you will be fine.
Patrick Asselman
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
