Hi all,
I have an assembly and its associated drawing with same name. I'm trying to develop a toolkit program that replaces assembly component using interchange groups. The assembly updates succesfully, but when I checks the drawing, the dimensions turn purple indicating that the references are being lost.
But when I try to perform the exact interchange group replacement manually through Creo UI, both the assembly and drawing updated correctly with no issue.
Below is the simplified version of my implementation:
I've tried various combinations of sheet and view regeneration, window activation and refreshing API's but to no success. Is there any specific regenerate/refresh sequence required to properly update the drawing dimensions when replacing components using interchange method? Any guidance would be greatly appreciated.
Thanks!
Hi @sk_12211084
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
