You can check whether you are eligible for RSD Lite by going to this link.
Does the jvm.dll error occur when installing RSD or when you are running it after installation? Also, what version are you trying to install?
Also, according to this PDF Routed Systems Designer runs on Windows XP, Windows Vista and Windows 7 (32- and 64-bit).
Martin
Martin, Thank you for your reply. I checked the link and it has detailed info. According to that I don't think we're eligible.
We puchased a Routed Systems extension I think a while back and we didn't continue to pay maintenance on it but we can't even access the option.
We're on WF5 now.
#PROBUNDLE_10105 1 Routed Systems Option Wildfire Flt Opt perm
Is it possible that our license is set up wrong because even without maintenance on this particula extension we still should be able to acces it.
I don't know for certain - I don't handle licensing. However, I believe there should be a RSDESIGNER_LITE option in the license that makes it available for you. When did you get that license?
Are you able to get Cabling going in Wildfire 5? If so, you *should* be able to get RSD going but may need input from someone more familiar with the licensing.
Martin
Thank you for your response.
We don't have Cabling, the Routed System Option license we purchased a few years ago with Pro/E2001 , then upgraded once to WF, and never paid maintenance on that option ever since.
I was just thinking that even without maintenance we should be able to sue that particular option/extension. But it's grayed out.
I am using RSD 6.0 lite and installing it on 64 bit windowsxp. getting message of missing file. Is RSD lite compactible 64-bit.
