Re: Global Parameter or Global X-Refs
Highlighted
Newbie
Guru's,
I'm looking to create a global parameter that can be modified by a family
table column. The idea is to enter an integer value into the family table
of the top level assembly and have the value propagate down to the part
level. There will be relations in certain parts that will utilize the single global parameter within a formula to create the necessary part size for
the top level assembly.
Is this possible?
Tony Mason
Rockwell Automation
R & D - Mechanical Designer
Rockwell Automation Canada
135 Dundas Street
Cambridge, ON N1R 5X1, Canada
