I've been working on a project to read dimension & gd&t values from a drawing. I'm successful in reading dimension but not gd&t. Could anyone please guide me how to do it?
I am pretty sure that is only available via Pro/TOOLKIT or a special module within Object Toolkit.
Dave
Dave
Hi Dave,
Thanks for the reply. I just have a follow up question. Did you try to do this by yourself or do you have any official reply/statement from Creo community or PTC people? If have to try & get Toolkit License I need to show something in my office. So I need some confirmation.
This is something you will have to confirm... but I am 99% sure that the GD&T info is only available via ObjectToolkit API + an additional license for this specific information. You can get to some of it via Pro/TOOLKIT - but I would not bet that will be as complete or as capable as the latest APIs.
I would recommend you chat with PTC rep about the best options.
Dave
Hi Dave,
Thank You so much for the information.
Can you please provide me the codes to extract dimensions from creo drawings using VB API..will be helpful
I can currently extract dimensions from model but unable to extract from drawings
