Recommended Settings for Visualization in R8 M040
ChrisCollinson
6-Contributor
Hi Visualisation Guru's
I am just about to start configuring our PV adaptors to try and make the images a little more light weight and wondered if any of you have been through the same exercise and had good results and if you would share your settings
We are publishing ProE WF2 data via WIndchill PDMLink with a CAD Worker on a seperate box to the Windchill Server. I want ot reduce the file size as much as possible and not too worried about some loss of detail as long as the end user can see that the object kinda looks like what their after, not explaining very well but need to reduce download time of visualisation to external support persons
Thanks in advance for any help
Chris C
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
