Retrieve model in toolkit
SOLVED
Re: Retrieve model in toolkit
Doc suggests that file UgUnicodeTranscoding.c is located at <creo_
toolkit_loadpoint>/protk_appls/pt_userguide/ptu_main.
But could not find the same with Creo 4.0 M030
@Ketan_Lalcheta  its available in Creo2.
I don't believe that this is the problem, because you provide the input string.
str_type_table[] =
{(char *)"sec", PRO_2DSECTION},
{(char *)"prt", PRO_PART},
{(char *)"asm", PRO_ASSEMBLY},
{(char *)"drw", PRO_DRAWING},
{(char *)"mfg", PRO_MFG},
{(char *)"lay", PRO_LAYOUT},
{(char *)"frm", PRO_DWGFORM},
{(char *)"rep", PRO_REPORT},
{(char *)"mrk", PRO_MARKUP},
{(char *)"dgm", PRO_DIAGRAM},
{(char *)"???", PRO_TYPE_INVALID}
// You parse your file name
ProFilenameParse(sel_path, def_path, w_name, w_type, &version);
//Get the type (based on table above)
ProWstringToString(str, def_path);
ProUtilConfirmNameType(str, line, &type)
//Open the model you may need to change the dir
ProMdlRetrieve(w_name, (ProMdlType)type, (ProMdl*)&comp);
Search at the sample folder.
In Tcl this is done in 2 min, check the section Files - Open, save, erase Creo files or the Windchill Section
@RPN  in this case w_name if retrieved from Creo interface there wont be an issue, where as if its been retrieved from any other interface ex. text file then creo shows error.
You can’t directly compare the Creo Interface with Toolkit. All model types are handled in one table without the need to have the 4 chars for the extension, instead you have an integer for the type.
@RPN
I have list of files(File Name) to be retrieved in session in a text file.
Now creo have to read the text file and pass it to function ProMdlRetrieve.
I learnt that there should be  conversion using ProNativewstringToWstring
How is you input file encoded? UTF? Use notepad and encode as ANSI.
If you use 'test.prt' than I can't believe your story, you need only to convert to wchar (2 bytes per char max).
Tcl Section Files - Open ...
# read the file
set fp [open models.txt]
set models [split [read $fp] \n]
close $fp
# Open the models in session
# if already in session skip to open the model
foreach model $models {
        if {![ps_model exist $model]}
                ps_file open $model
@RPN  is TCL related to Toolkit.If no, kindly try the same using toolkit. I got the error also I have attached the screen shot of the error message in earlier post.
It is based on Toolkit, how do you thing you can archive this without 🙂
int
ps_test_Open_File (
	ProName       		w_modelname;
	ProMdl       		Model;
	ProError			tk_status;
	ProStringToWstring(w_modelname,"TEST");
	tk_status = ProMdlRetrieve(w_modelname,PRO_MDL_PART,&Model);
	return tk_status;
Compile and try. It is working for me!
