Set accuracy of Edge Tessellation
Florian0205
8-Gravel
I´ve used the ProEdgeTessellationGet() method in my CreoToolkit App, but realized that I only get a few points as an output (22 points for a 180° 200mm arc). Is there any possibility to get a better tessellation of Arcs, etc. or to even set a distance between the  points of the output with the ProEdgeTessellationGet method?
Thanks in advance
0 REPLIES 0
