Hi Team,
In creo by default there are 3 decimal places in all the dimensions or what we set to.
I want to preset the hole dimensioning in creo model and drawing to '2' by default without affecting the rest of the dimensioning scheme. i.e. rest of the features follow default scheme of 3 decimal.
Can anyone please let me know if there is a way to define custom decimal places only for holes? I would appreciate your help with it.
protoolkit has a functionality to handle custom dimension schemes.
the actual worker function is ProDimensionDecimalsSet(...).
one would need either to write a custom utility to examine the existing drawing dimensions and modify their significant digit number if search conditions were met or to write a make-new-dimension utility with the predefined number of significant digits.
HIH
HIH
