I'm trying to setting up creo, for vbapi.
I've followed the steps in VBUG.pdf file.
1st- Add the environment variable PRO_COMM_MSG_EXE =C:\Program Files\PTC\Creo 5.0.0.0\Common Files\x86e_win64\obj\pro_comm_msg.exe
2nd- Then I run the file: C:\Program Files\PTC\Creo 5.0.0.0\Parametric\bin\vb_api_register.bat
Then I should be able to add the references to my vb projetc. But there is no COM references for CREO.
What am I missing?
Below should be your quick check points:
1. PRO_COMM_MSG_EXE path should not be having space. If path is having spaces, try to convert path as short path and set this path as environment variable value.
2. Hope you are setting System level Environment variable.
3. Hope you are running bat file with admin access.
-HIH
Ketan
-HIH
Ketan
