Showing combined State view with annoations in the CAD drawing
jstewart-2
2-Explorer
Software used: Creo 8.0.
When I set up combined state view in the model I can show different dimensions and annotations in each combined state view, but when add a new view to the drawing and select the combined state view, the annotations and dimensions are not displayed in the drawing as they are in the model.
When I select show model annotations for the drawing view it shows every single dimension available not just the annotations and dimension I displayed in the Model according to the combined state view.
In older versions of Creo, this was possible, not sure if there is a setting that should be changed in new versions.
There seems to be a bug, and PTC is currently not working on a fix, see:
https://www.ptc.com/en/support/article/CS255181
This is a important aspect of MBD, a lot of companies still rely on drawings and without this functionality the benefits of MBD are reduced.
Van_AG
(To:jstewart-2)
Try to use not combined state, but saved orientation witch used in combined states and config option
auto_show_3d_detail_items == yes
Set combined states in model.
Check that auto_show_3d_detail_items is set to default value "yes".
And in a drawing view just set saved orientation witch used in model combined states
It seems to work in Creo 8.
