I made a Skeleton family table
I Need to replace a skeleton with an other instance.
Seems like it should work. Manually using 'Replace' works fine in Creo for swapping skeleton family table instances. You will probably need to open a case with Sigmaxim tech support and ask them why it's not working.
thank's i open ticket to Sigmaxim
just for information, SIGMAXIM said it's not possible to REPLACE Skeleton with SMART ASSEMBLY
Maybe, you can use ProProgram for this? Set the name of the instance to model parameter and use this name in proprogram.
