Thanks to all for the replies...below is the summary to accomplish what I
needed. Both worked, Thanks!
1. I use to redirect the output stream from within my J-link
applications. If you insert this code in the first J-link application that
is started, it sets the output streams for the hole session of ProE, which
means all other J-link applications as well.
try
{ System.setOut(new PrintStream(new
FileOutputStream("c:\\protrail\\jlink_system_out.txt")));
System.setErr(new PrintStream(new
FileOutputStream("c:\\protrail\\jlink_system_err.txt")));
catch(IOException io)
{ io.printStackTrace();
2. If you redirect std.out from Proe when you start it up, then your Jlink
output will be written there. For example proe > out.txt.
