Summary: MDX Question
mdolata
Thanks for the replies. There were only a couple so I'll just summarize
here.
Looks like the best way to do what I want is to create different "fill
volume" parts (most easily done in a family table) which represent the
volume at different stages then use the Display@Time function to turn on
or off only the fill volumes required at any point in time. Another way
would be to add a transparency characteristic to the part using Trans@Time
which could make it fade in and out if desired. It's a bit of work to set
up either way but it seem like the most practical methods and can be done
entirely inside Pro/E.
Regards
Mark Dolata
CenterLine (Windsor) Ltd. - Automation Components Division
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
