Summary: Treble clef model
Highlighted
Newbie
Thanks for your quick replies. I have attached a true type font file and a 3d model in iges format.
Vassilis
ANSWER
Good morning Vassilis!
I've attached a True Type font that I downloaded (freeware)... The treble clef is the G character in this font set. Place this .ttf in the C:\PTC\wildfire2\text\usascii directory and add this line to your config.pro.
pro_font_dir C:\PTC\wildfire2\text\usascii
You should be able to select this font in the sketcher!!
ORIGINAL QUESTION
any musicians out there? I am looking for a model of the treble clef. 2d geometry is also acceptable, in any format such as dxf, dwg etc
