Surface region
shinoy.sivan
Surface region
Surface regionHi all, Thank you for the solutions what you sent me last time. Can anyone suggest me how we can create surface region inside a pipe. With surface region I would like to cut the inner surface of the pipe to apply pressure inside. Thanks in advance. Regards,Shinoy C SMember Technical Staff-Team AnalysisHCL Technologies Ltd"Surya Sapphire",PLot No.3,1st Phase,Electronic cityBangalore, IndiaPhone:+91-80-66267809Mobile:+91-9986006040www.hcl.inP Please don't print this E-mail unless you really need to. Save paper save environment
RE: Surface regionHi guys, Sorry to disturb you again. I found the solution myself. Nothing but create a straight line(equal to inner diameter of pipe) on a datum plane. And while you creating surface region select this line as sketch.It will solve the problem. With Regards,Shinoy C S_____________________________________________
