Hello to everyone,
I am in a project where I want to display symbols on a drawing... but these symbols are intended to come from 3D annotation features and they are displayed on the drawing. That works fine so far - the methods ProAnnotationByComponentShow() and ProAnnotationByFeatureShow() bring the desired symbols to the drawing.
Now I am looking for a way to manipulate these "2D instances", the most common task may be to modify the position of the symbol instance.
My problem/question:
The normal procedure to modify a symbol's position by editing the ProDtlsyminstdata object doesn't work with symbols owned by the 3D annotation. Method ProDtlsyminstModify() returns a -1 code always.
The only symbols (coming from annotations in the solid model) that can be modified with ProDtlsyminstModify() seem to be symbols inside welding features - there is a function ProFeatureDtlsyminstGet () where you can get the 2D instance from the owner feature.
Any experience with this???
I know that there is a additional license for Toolkit "3D drawings", but I am talking explicitly about showing/manipulating symbols on drawings. I know that the functions in the additional toolkit license can modify the 3D position in the model, but even with the additional license I haven't found anything for 2D mode.
Thanks for all comments and suggestions.
Andreas
