Toolkit Config.pro
Marcusanthony
Toolkit Config.pro
Hello all,
I am trying to change a configuration option using C++ toolkit. But I am facing issue to know the correct syntax. Can anybody please provide me with syntax?
tbraxton
(To:Marcusanthony)
If you want to change only a single option setting directly without loading files, then consult this article:
Article - CS122393 - How to Get / Set / Restore / Delete a configuration option (single/multivalued) through Toolkit customization in Creo Parametric (ptc.com)
Involute Development, LLC
Consulting Engineers
tbraxton
(To:Marcusanthony)
Load a config file with the change to the option(s).
Function ProInputFileRead() with PRO_CONFIG_FILE as file_type to load config file.
Marcusanthony
(To:tbraxton)
Is there no method to change value to one configuration option value from yes to no?
I am trying to change config.pro option value.
tbraxton
(To:Marcusanthony)
HannesBuxbaum
(To:tbraxton)
Do you know if ProInputFileRead() also changes config.pro options that refuse to be changed by SetConfigOption()/ProConfigoptSet()?
See https://www.ptc.com/en/support/article/CS334060
"Setting export_profiles_creoview with SetConfigOption() does not of effect in the current session"
The export_profiles_step option is another such "victim" that is immutable during Creo session, as I experienced myself.
