Toolkit and Visual Studio error
joe_c
I am getting an error in Microsoft Visual C++ 2010 Express, while loading the make_install.sln.   The error says:
"<creo_toolkit_loadpoint>\make_install.vcxproj : warning : Platform 'x64' referenced in the project file "make_install" cannot be found.  Please make sure you have installed under '%VCTargetsPath%\Platforms\x64".
i have Creo 2.0 in 64-bit and VS installed in 32-bit. Is this problem that is asking me? ran it as admin and regular as well -same problem
thanks
5 REPLIES 5
MarkStallard
(To:joe_c)
Hi Joseph -
I ran a Google search on the phrase "platform 'x64' referenced in the project file cannot be found" and found several pages where people reported this problem with Visual Studio 2010 Express, even though search string doesn't mention that application. Comments on at least two of those pages stated that VS 2010 Express does not contain a 64-bit compiler, even though the full version of VS 2010 does. The recommended solution was to download and install the Microsoft Platform SDK for x64.
Do you know whether you have a 64-bit compiler installed?
|+|  M a r k  |+|
FV
(To:MarkStallard)
Hi all,
With VS express one needs to install a platform sdk. There was a discussion a  number of years back with a good explanation how to use/configure the 'express' edition of VS.
HIH.
Feliks.
joe_c
(To:FV)
The problem i read with SDK is only compatible with Windows 7 and below.  I am running windows 10 x64bit.  I take SDK will work for both x86 and x64 as well but has anyone it use with Windows 10?
https://www.microsoft.com/en-us/download/details.aspx?id=2680
joe_c
(To:joe_c)
Mark
Is that microsoft compiler same as Eclipse or Netbeans?  Because i havent downloaded either one just yet and was steering tores Eclipse.  Looks like MS Visual studio is similar to Eclipse. Will i be able to open the make_install.sln or vcproj files in Eclipse.. Visual Studio express is a huge bundle of basic, c++,c,webdeveloper,etc that i just cant justify installing it. Is it required? if we can get away with a more simple, compact version like Eclipse, i jump on it.
Mark, did you use MS Visual studio during the toolkit configuration?
MarkStallard
(To:joe_c)
Joseph -
Eclipse and Netbeans are IDEs that are typically used for Java. While Eclipse has an edition for C++, I don't know anybody who has used it for Creo Parametric Toolkit or OTK C++. On the other hand, I do know people how have successfully used the Microsoft Platform SDK (including myself) with Creo Parametric Toolkit on older versions of Creo (Wildfire 2).
PTC is quite clear when it states support only for specific versions of Microsoft compilers and libraries for Creo Parametric Toolkit. Once or twice I tried using something different, but I never succeeded.
|+|  M a r k  |+|
