Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Is there a way to call up upper and lower limits. I'd like to put them in family table, as I'm running into problems where my limits are 3 decimal places and my mean would be 4. I'd rather just use my limits instead of the mean dim. I'm currently using the tp10 for d10 to create a relation so I can control parameters to appear like limits DUL & DLL. I would like something simpler if it exists. TIA
Eric Fleming | Engineering Technician ITT Corporation, Residential & Commercial Water, 1 Goulds Dr., Auburn, NY 13021 Phone: 315-258-4840 | Fax: 315-258-4809 | -<">mailto:->
