User Defined Struct Crashing Creo to Fatally Crash
Hello community,
I am working on creo 9.0.2.0
I am defining my own struct as this:
typedef struct ParmNote {
struct ParmNote *Next;
struct ParmNote *Last;
char Note[120];
wchar_t wcNote[120];
}NOTE_PARAM;
In a later function I have:
NOTE_PARAM *Current , *Next , *Last , *First;
First = (NOTE_PARAM *)(mParm->PString);
Last = First->Last;
Current = Last;
Next = (NOTE_PARAM *)malloc(sizeof (NOTE_PARAM));
Current->Next = Next;
First->Last = Next;
Current = Next;
Current->Next = NULL;
When it reaches the underlined line of code "Current->Next = Next;", creo fatally crashes. I do not understand why this is causing Creo to crash, as this exact logic worked in Creo 5.
Any and all help would be appreciated.
Thank you,
Mark Hardebeck
FV_01
FV_01Answer
June 9, 2023
if you would rewrite code to eliminate unnecessary variable assignments and replace malloc with calloc(...) to have allocated memory initialized:
 NOTE_PARAM *first = (NOTE_PARAM *)(mParm->PString);
 //assert(NULL == first->Last);
 if( NULL != first && NULL == first->Last){
 first->Last = (NOTE_PARAM *)calloc(1, sizeof (NOTE_PARAM));
 //assert(NULL != first->Last);
 //assert(NULL == first->Last->Next);
the reason for crash would be easier to detect.
HIH
KenFarley
Are you sure that the data contained in mParm->PString is compatible with NOTE_PARAM?
Have you verified that the pointer First->Last is indeed valid, not NULL, and not random data created when memory was allocated? It's a good rule to always initialize pointers to NULL or the equivalent when they are created, and verification before use is imperative.
If First->Last is not a valid pointer to a properly allocated NOTE_PARAM structure, that would wreak the havoc you are seeing.
Yes, I have verified that mParm->PString is compatible and that First->Last is not NULL.
FV_01
FV_0117-PeridotAnswer
June 9, 2023
HIH
