Dear
Please help me example VB API in Creo
Create a button1 select CSYS in Creo then get name show in textbox1 in VB.
I want to create button in VB so select object in Creo, I had read ptc document but difficult for me to find example.
I couldn't resist, in Tcl I need this:
# Assume a 3D model is active, # and contains only one (to make the result clear) Csys with feature ID 11 # The Csys/Type/Geom ID off the Csys is 58 # No error checking in this code here
# Create Selection Object 'selObj' is the name of the object ps_sel selObj # Now ask the user to select a 'csys' (controls goes to Creo) selObj select csys # back from Creo, get the model item, note you selected a CSYS and not a FEATURE selObj modelitem miObj # Get the CSYS GeomID, after this command, GeomID will hold 58 set GeomID [miObj cget -id] # Get the Feature ID, after this command FeatID will hold the Value '11' set FeatID [ps_geom to_feat_ids CSYS $GeomID]
For the selection only, 2 lines of code ![]()
Dear Sir
Thanks your reply, I had follow your code but error.
I'm using Visual Basic 2016 Windows form Application not C# (I dont know)
I want to get name CSYS to textbox1
Thanks advance your help
That's simple, you have the model handel, and the feature ID, now you can get the feature name with this two references. In Tcl, working on the current model:
# Get the Feature Name set FeatName [ps_feat name $FeatID]
Dear Sir
Can you help more detail
I don't want feat ID,
I just want create a button in VB API => then select one of any Csys in Creo => then get name to textbox1 in VB API
Hello CCT, no I will and I can't provide a VB script, because I don't use VB, it's hard to read for me and you need to write so much code. I did it with Tcl, on the fly (All options need a leading '-' 🙂 )
Now have fun with VB!
proc Init {} {
# Destroy for ReRun, else on ReRun an error would generated
destroy .ptc
ps_destroy miObj selObj
# Main Window
toplevel .ptc
# Place it
wm geom .ptc -400+200
# Button and Entry with text a global variable
pack [button .ptc.b1 -text "Select CSYS" -command SelectAndUpdate]
pack [entry .ptc.e1 -textvar NAME_OF_MODELITEM -width 35 ]
# Craete modelitem and selection Object/Command, selObj will reference the miObj
ps_modelitem miObj -update yes
ps_sel selObj -modelitem miObj
proc SelectAndUpdate {} {
# Select the Csys
selObj sel csys
# Get the data to the global var ::NAME_OF_MODELITEM this will update the entry value
set ::NAME_OF_MODELITEM "Name: [miObj cget -name] ID: [miObj cget -id] Type: [miObj cget -type]"
Init
