VBA, Component parameter
Azad_Chowdhery
8-Gravel
Related to this topic
I want to do the same. Would you be able to furnish the VBA code?
I'm sorry but I don't have any code to give you. The direct parameter reading project failed two years ago.
  • A Component Parameter can be created/read/deleted in an assembly for each model item where the type is a feature and the feature type is a component.
cko
(To:Azad_Chowdhery)
PART LIST PROGRAM 블로그 : https://idt21c.tistory.com/415
