VBA scripting in CREO
bnelson-3
In all the PTC/CREO suport materials, are there examples of using Excel's VBA to drive repetative operations in CREO?  Thank you.
Chris3
(To:bnelson-3)
When you say "repetitive operations" what are you referring to?
You can use Excel to drive geometry:
http://learningexchange.ptc.com/tutorial/188/creating-an-ms-excel-analysis-feature
Creo 2.0 e Excel - YouTube
You can also use VBA to interact with the VB Toolkit. This can be complicated to setup and is not entirely user friendly.
Creating a Creo2 Tool with Toolkit
Examples: <load_point>\Common Files\<Datecode>\protoolkit
Alternatively you can record a mapkey and then edit the mapkey to suit your needs.
