When I want to create sketch feature,
wfcElement::Create(PRO_E_STD_FEATURE_NAME) is always not be correctly, It always disappear.
The RightPlane can not be obtained!!
Help me!!!!! 😂
pfcSession_ptr session = pfcGetProESession(); if (session == NULL) { OutputLogMsg("failed to obtain creo session."); return; } wfcWSession_ptr Wsession = wfcWSession::cast(session); // 取得目前模型(確認為零件) pfcModel_ptr model = session->GetCurrentModel(); if (!model || model->GetType() != pfcMDL_PART) { OutputLogMsg("failed to obtain PART model."); return; } // 將模型轉型成 Solid 物件(支援草繪) pfcSolid_ptr solid = pfcSolid::cast(model); wfcWSolid_ptr Wsolid = wfcWSolid::cast(solid); // 檢查目前模型是否為有效的 Solid 物件 if (solid == NULL) { OutputLogMsg("failed to get Solid from current model."); return; } // =============================================== // 嘗試取得名稱為 "TOP" 的基準面 pfcModelItems_ptr Items = solid->ListItems(pfcITEM_FEATURE); pfcModelItem_ptr TopPlane = nullptr; pfcModelItem_ptr RightPlane = nullptr; for (int i = 0; i < Items->getarraysize(); i++) { pfcFeature_ptr feat = pfcFeature::cast(Items->get(i)); if (feat->GetName() == "TOP") { TopPlane = feat; } else if (feat->GetName() == "RIGHT") { RightPlane = feat; } } if (!TopPlane || !RightPlane) { OutputLogMsg("failed to get TOP or RIGHT plane."); return; } xstring treeInfoFile = "C:/temp/ElementTree_Info.txt"; // 建立暫存檔案來儲存Element Tree資訊, 作為查閱之用 // =============================================== // 建立 ElementTree (草繪曲線特徵設定) wfcElements_ptr elems = wfcElements::create(); elems->append(wfcElement::Create(PRO_E_FEATURE_TREE, nullptr, 0)); elems->append(wfcElement::Create(PRO_E_FEATURE_TYPE, pfcCreateIntArgValue(PRO_FEAT_CURVE), 1)); elems->append(wfcElement::Create(PRO_E_CURVE_TYPE, pfcCreateIntArgValue(0), 1)); elems->append(wfcElement::Create(PRO_E_STD_FEATURE_NAME, pfcCreateStringArgValue("QQ_SKET"), 1)); elems->append(wfcElement::Create(PRO_E_STD_SECTION, nullptr, 1)); elems->append(wfcElement::Create(PRO_E_STD_SEC_SETUP_PLANE, nullptr, 2)); elems->append(wfcElement::Create(PRO_E_STD_SEC_PLANE, pfcCreateSelectionArgValue(pfcCreateModelItemSelection(TopPlane)), 3)); elems->append(wfcElement::Create(PRO_E_STD_SEC_PLANE_VIEW_DIR, pfcCreateIntArgValue(1), 3)); elems->append(wfcElement::Create(PRO_E_STD_SEC_PLANE_ORIENT_DIR, pfcCreateIntArgValue(2), 3)); elems->append(wfcElement::Create(PRO_E_STD_SEC_PLANE_ORIENT_REF, pfcCreateSelectionArgValue(pfcCreateModelItemSelection(RightPlane)), 3)); //elems->append(wfcElement::Create(PRO_E_SKETCHER, nullptr, 2)); wfcElementTree_ptr elemTree = Wsession->CreateElementTree(elems); // 建立元素樹,該樹描述了整個特徵的定義 // =============================================== wfcFeatCreateOptions_ptr opts_INCOMPLETE = wfcFeatCreateOptions::create(); opts_INCOMPLETE->append(wfcFEAT_CR_INCOMPLETE_FEAT); wfcWRegenInstructions_ptr regenInstrs = wfcWRegenInstructions::Create(); // 創建重生指令,確保模型在特徵建立後進行更新 wfcWFeature_ptr Wfeature_sketch = Wsolid->WCreateFeature(elemTree, opts_INCOMPLETE, regenInstrs); // 創建草繪曲線特徵 // =============================================== elemTree = Wfeature_sketch->GetElementTree(0, wfcFEAT_EXTRACT_NO_OPTS); // 取得特徵的元素樹 // =============================================== wfcElements_ptr elems_ = elemTree->ListTreeElements(); for (int ii = 0; ii < elems_->getarraysize(); ii++) { if (elems_->get(ii)->GetId() == PRO_E_STD_SEC_PLANE) { elems_->get(ii)->SetValue(pfcCreateSelectionArgValue(pfcCreateModelItemSelection(TopPlane))); } else if (elems_->get(ii)->GetId() == PRO_E_STD_SEC_PLANE_ORIENT_REF) { elems_->get(ii)->SetValue(pfcCreateSelectionArgValue(pfcCreateModelItemSelection(RightPlane))); } } elemTree = Wsession->CreateElementTree(elems_); elemTree->WriteElementTreeToFile(wfcELEMTREE_XML, "C:/temp/ElementTree_Info_2.txt"); // 將元素樹寫入到檔案中, //================================================ // 建立存取 PRO_E_SKETCHER 的元素路徑 (PRO_E_STD_SECTION → PRO_E_SKETCHER) wfcElemPathItems_ptr ElemPathItems = wfcElemPathItems::create(); ElemPathItems->append(wfcElemPathItem::Create(wfcELEM_PATH_ITEM_TYPE_ID, PRO_E_STD_SECTION)); ElemPathItems->append(wfcElemPathItem::Create(wfcELEM_PATH_ITEM_TYPE_ID, PRO_E_SKETCHER)); wfcElementPath_ptr sketchPath = wfcElementPath::Create(ElemPathItems); wfcElement_ptr sketchElement = elemTree->GetElement(sketchPath); wfcSpecialValue_ptr sketchSpvalue = sketchElement->GetSpecialValueElem(); wfcSection_ptr section_sketch = sketchSpvalue->GetSectionValue(); if (section_sketch == nullptr) { OutputLogMsg("failed to get sketch section."); return; } //================================================ pfcPoint2D_ptr center = wfcCreatePoint2D(0.00, 0.00); wfcSectionEntityCircle_ptr circle = wfcSectionEntityCircle::Create(center, 25.00); section_sketch->AddEntity(wfcSectionEntity::cast(circle)); pfcOutline2D_ptr line1 = wfcCreateOutline2D(-10.00, 20.00, 10.00, 20.00); wfcSectionEntityLine_ptr lineEnt1 = wfcSectionEntityLine::Create(line1); section_sketch->AddEntity(wfcSectionEntity::cast(lineEnt1)); pfcOutline2D_ptr line2 = wfcCreateOutline2D(10.00, 20.00, 10.00, -20.00); wfcSectionEntityLine_ptr lineEnt2 = wfcSectionEntityLine::Create(line2); section_sketch->AddEntity(wfcSectionEntity::cast(lineEnt2)); pfcOutline2D_ptr line3 = wfcCreateOutline2D(10.00, -20.00, -10.00, -20.00); wfcSectionEntityLine_ptr lineEnt3 = wfcSectionEntityLine::Create(line3); section_sketch->AddEntity(wfcSectionEntity::cast(lineEnt3)); pfcOutline2D_ptr line4 = wfcCreateOutline2D(-10.00, -20.00, -10.00, 20.00); wfcSectionEntityLine_ptr lineEnt4 = wfcSectionEntityLine::Create(line4); section_sketch->AddEntity(wfcSectionEntity::cast(lineEnt4)); section_sketch->SetIntentManagerMode(true); // 啟用意圖管理器模式, 進行完成截面定義 (在截面section_sketch中建立2D實體) section_sketch->SetIntentManagerMode(false); // 完成截面定義,關閉意圖管理器模式 // =============================================== wfcElements_ptr elements_NEW = Wfeature_sketch->GetElementTree(0, wfcFEAT_EXTRACT_NO_OPTS)->ListTreeElements(); for (int ii = 0; ii < elements_NEW->getarraysize(); ii++) { if (elements_NEW->get(ii)->GetId() == PRO_E_SKETCHER) { elements_NEW->get(ii)->GetSpecialValueElem()->SetSectionValue(section_sketch); break; } } for (int ii = 0; ii < elements_NEW->getarraysize(); ii++) { if (elements_NEW->get(ii)->GetId() == PRO_E_STD_SEC_PLANE) { elements_NEW->get(ii)->SetValue(pfcCreateSelectionArgValue(pfcCreateModelItemSelection(TopPlane))); } else if (elements_NEW->get(ii)->GetId() == PRO_E_STD_SEC_PLANE_ORIENT_REF) { elements_NEW->get(ii)->SetValue(pfcCreateSelectionArgValue(pfcCreateModelItemSelection(RightPlane))); } } wfcElementTree_ptr elemTree_NEW = Wsession->CreateElementTree(elements_NEW); elemTree_NEW->WriteElementTreeToFile(wfcELEMTREE_XML, "C:/temp/ElementTree_Info_3.txt"); // =============================================== wfcFeatCreateOptions_ptr opts_NO_OPTS = wfcFeatCreateOptions::create(); opts_NO_OPTS->append(wfcFEAT_CR_NO_OPTS); Wfeature_sketch->RedefineFeature(NULL, elemTree_NEW, opts_NO_OPTS, regenInstrs);
Hi @CC_12210022,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. Like:
It sometimes helps to have screenshots to better understand what you are trying to do.
Vivek N
Community Moderation Team
HI,can use ProModelitemByNameInit(); output the "RIGHT" name datum plane.
