When using promold catalog for clearance cuts..
snguyen
I found out by accident if you use clearance cuts in a mold for an ejector
pin when you go into ProNC you can not pick holes by size normally.
But if you create another part using inheritance or merge of the original
part you can select by hole size again. Only thing is in the original part
you will need to create axis in each hole. The inheritance or merge feature
can be dependant.
Now if we can get the auto axis toolkit I can have mold components that are
easy to program in ProNC.
Son Nguyen
785-667-7763
108 W. 2nd Street
Assaria, Kansas 67416
0 REPLIES 0
