Where is the default location of Creo Parametric?
OS_11014878
Where ist the default location of Creo Parametric while it´s connected to windchill?
When i search it in Creo itself it shows me that path: wtws://XYZ/DEFAULT Creo/
But this path cannot be found in the explorer.
I am trying to find the local workspace in my explorer.
TomU
(To:OS_11014878)
They are not encrypted, but they are renamed.  Windchill manages the relationship between the filename on disk and the 'real' name (that Creo sees.)  Files that start with sid_ are files that were downloaded from Windchill and files that start with lid_ are files that were created locally.
JB_87049
(To:OS_11014878)
Can't that be found in your AppData folder?
Out of curiosity, what do you want to do?
No, it cant be found there.
It´s also a curiosity of mine to understand how the system works.
In some cases it could be usefull to find the files in a folder than just in Windchill.
Van_AG
(To:OS_11014878)
Local workspace default location is
%appdata%\PTC\ProENGINEER\Wildfire\.wf\.cache2008\
Just copy-paste this string to the Windows Explorer address bar and press Enter )
But local workspace location may be changed by system variables PTC_WF_CACHE.and PTC_WF_ROOT.
So better way - open in Creo menu 'File' > 'Manage Session' > 'Server management' > 'Cache' tab > copy path from 'Location' field.
OS_11014878
(To:Van_AG)
Thanks, i found the Cache and there are folders with files.
But not the prt or asm files, I found mostly WFCONT files. Is it possible that the files are encrypted?
TomU
(To:OS_11014878)
