First, I'm not sure if this is the correct forum for GRANITE questions. If not, please point me to the appropriate community.
I'm creating a KBody instance and for some reason KBody::IsReversed() is returning true. When I ask the triangulator to create tristrips for me, they are coming back with the normals pointing inwards. Is it up to me to reverse the tristrips and normals?
Cory
I did get a response from GRANITE tech support. Unfortunately it wasn't what I wanted to hear. There isn't much I can do. Essentially, it's just the way the API works.
FWIW, I was following the procedure from task 9 in the GRANITE User Guide.
Hi @Cory,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
