1. I have a toolkit "Callback ProTkdllFunction" named io() as listed below.
2. Call io() from Web.Link OK but count of the output ProArguments from io() is always 0 while it should be 1.
3. Problem must be somewhere in the function io() <-- I need help to find it.
The way to call io() from Web.Link :
sess.GetProToolkitDll("115937605053").ExecuteFunction("io",iArg)
#define DllExport __declspec( dllexport )
DllExport int io(ProArgument * inputs, ProArgument ** outputs){
ProArgument *args;
// compose the output ProArgument array , refer to protkdoc/api/provalue_h.html
ProArrayAlloc(1,sizeof(ProArgument),1,(ProArray*) &args);
ProValuedataStringSet( &(args[0].value), "hello world!");
outputs = &args;
return inputs->value.v.i; // echo the input ProArgument
You need to mention the output label and than set value. Using the same label you try to get the value in weblink.
Look at the following method.
void CreateOutputArgumentMessage(ProArgument** outputs, ProName label, char* message)
char trailline[PRO_COMMENT_SIZE];
ProError status;
ProComment returnMessage;
status = ProArrayAlloc(1, sizeof(ProArgument), 1, (ProArray*)outputs);
if (status == PRO_TK_NO_ERROR) {
ProWstringCopy(label, outputs[0]->label, PRO_VALUE_UNUSED);
outputs[0]->value.type = PRO_VALUE_TYPE_WSTRING;
ProStringToWstring(returnMessage, message);
ProValuedataWstringSet(&outputs[0]->value, returnMessage);
ProError status;
ProError status;
ProArgument *args; // output array
ProName label = L"I am the label";
char message[] = "I am the message";
CreateOutputArgumentMessage(&args, label, message);
outputs = &args;
ProArray allocated in the ProTkdllFunction like this:
How can the Web.Link caller do the ProArrayFree() and even ProArgumentProarrayFree() too?
