currently I don't have a INTRALINK or PDMLink installation available and a customer asks the following (simple?) question:
Is it possible to get a list of models that are currently in the (current/active) workspace?
Toolkit, Weblink/VB/Jlink ???
With WF5 I know there is an enhancement in the ProFilesList() command where you can use a wtws:// (or something like that) as the directory path.
But does anyone know what's the correct command/method in Wildfire 4?
Thanks.
Andreas
__________________________________
Andreas Hellmann
MCAD Services Pro/E & Pro/E customization
Rudolf-Diesel-Str. 6
D-65439 Floersheim / Germany
phone: +49 6145 598296
mail: -
I think some clarification is needed.
If you are not using INTRALINK ro PDMLink, workspaces are not used and therefore do not exist.
Gerry
In Reply to Andreas Hellmann:
Toolkit, Weblink/VB/Jlink ???With WF5 I know there is an enhancement in the ProFilesList() command where you can use a wtws:// (or something like that) as the directory path.
Andreas, take a look at the last post in this thread: http://portal.ptcuser.org/p/fo/st/topic=13&post=98587#p98587
Bjarne Frandsen
(Pro/ENGINEER Wildfire 4.0 M170andWindchill 9.1M060 on Windows)
