Bjarne,
Both my install at work and at homeappear to bemissing the VB API files.
The install directory <installation directory=">\ProENGINEER\vbapi\> does not exist.
Any Ideas where I can find these files?
I have the weblink and Jlink files but not the vbapi files
Don A
Hello Don
The VB API is included in the Wildfire 4 standard edition, but according to PTC there are problems using the VB API in Builds M030 and M040 (see SPR 1619234) and it only works correctly starting with Build M050.
To install the VB ABI you have to select the feature "Visual Basic API" located under API Toolkits during the installation of Pro/Engineer.
The VB API files are installed under the directory <proe_install_dir>\engineer\vbapi.
Kind Regards
David Rodriguez
Found what I was looking for.
The option was not selected when the install took place.
Thanks for everyone's help
Don A
