Windows Security Dialog (genlwsc.exe) Opening Behind Active Window
smarcus3
Every time I first get onto the windchill server in Creo and am connected to a Windchill server, the authentication dialog (genlwsc.exe) opens behind the active window as shown with its icon blinking yellow. Any solutions for this???
The current 'solution' https://www.ptc.com/en/support/article/CS303945, is to manually select it which isn't a solution.
Thanks.
10 REPLIES 10
BenLoosli
(To:smarcus3)
May not be a 'solution' but it is the current workaround.
Some of my users see this and some don't. Just depends on the mood of Windchill.
If your system is not up-to-date with Windows patches, then we get an EFX open error that totally blocks the Windows Security Dialog window. Have to kill the WIndows Security Dialog box, then OK the EFX error and then Windchill will let you login when you go through the Server Manager Window.
smarcus3
(To:BenLoosli)
Thanks for the reply. None of the user group gets an explicit error message, just the authentication dialog box opens behind Creo.
Hello@smarcus3
Try to change web browser type to other, by set config.pro option windows_browser_type
smarcus3
(To:YaroslavSin)
I like the idea; however, Chromium's authentication window also appears behind Creo
What Creo version and browser type you using?
smarcus3
(To:YaroslavSin)
Creo 4.0 M070
Windows 10
Happens with both IE / Chrome
As workaround, it is possible to write app in Autoit or AutoHotkey. The application must waiting authentication window and bring it to front.
AutoIt script. Compile this application. Looking for login window and bring the window to top. To close the app click by icon in system tray.
#NoTrayIcon
#include <MsgBoxConstants.au3>
#include <TrayConstants.au3> ; Required for the $TRAY_ICONSTATE_SHOW constant.
Opt("TrayMenuMode", 3) ; The default tray menu items will not be shown and items are not checked when selected. These are options 1 and 2 for TrayMenuMode.
Example()
Func Example()
    Local $idExit = TrayCreateItem("Exit")
    TraySetState($TRAY_ICONSTATE_SHOW) ; Show the tray menu.
	$classWnd = "[CLASS:Credential Dialog Xaml Host]" ;Login window class
    While 1
        Switch TrayGetMsg()
            Case $idExit ; Exit the loop.
                ExitLoop
		 EndSwitch
	  ; If windows is exist and not active (hiden under other windows)
	  If WinExists($classWnd) and Not BitAND(WinGetState ($classWnd),  Then
		 Local $r = WinSetOnTop ($classWnd, "", 1) ;bring to top
		 ;MsgBox($MB_SYSTEMMODAL, "", $r)
		 WinSetOnTop ($classWnd, "", 0)
	  EndIf
    WEnd
EndFunc   ;==>Example
PS: for IE browser
smarcus3
(To:YaroslavSin)
Thanks for the suggestion; however, I can't imagine I will be able to easily convince IT to install AutoIt or any other scripting software on all user's stations. I do like the solution as I'm sure it would resolve the issue however, I don't feel it will work for my case.
Thanks for putting together the code though @YaroslavSin . Kudos.
I see the resolutions are still being evaluated by PTC. Have you been able to learn anything more about this in the last 2 years?
