Working with Notes and parameters
KB_9100625
I have two question on the notes in creo 4.
1. can i change the default note name for ex Note_01 to Gen_note001
2. is there a way to create a parameter note without opening the parameter box itself like can i add a relation that would equate Note_001 to a parameter? (not &parameter name)
ex. note_001= Note Parameter named noteA_001
5 REPLIES 5
(1) You can change the note name directly by selecting it from the Drawing Tree.
(2) Notes cannot be manipulated by relations. The only way I know of to use String parameters in notes is to reference them as &parameter, but you don't want that.
(2a) Parameters are limited in their usefulness for notes. They have an 80 character (I think) limit on length. They can't, as far as I know, include carriage returns or other "line feed" characters, so can only specify at most one line of a note.
KB_9100625
(To:KenFarley)
ok so that makes sense i was wondering though if there was a config setting to change the default name so i dont have to click it to do so
Do you want show in note a text from a parameter in this note?
So i want to generate a note with "hello world" and i want it automatically be titled Gen_note"#" when it appears in the tree
Hi, IMO:
- regular mapkeys + clever hacks are not going to work.
- you can make a custom application with weblink / VB / toolkit
- look into Creo|SON and you can use a programming language of choice.
