Hello All,
I am merely trying to add a section on an existing datum plane in a new
assembly that I created. The following snippet of code is how I was
doing it. I was able to create the x-sec, but looking at it after the
fact (without toolkit, just Pro), it displays wrong in the assembly as
well as on a drawing. Plus if I try to alter the section Pro crashes.
Does anyone know a different approach I may take? Thanks.
ProError err;
ProError assy_err;
CString prt, prt2, prt3, prt4;
ProMdl mdl, comp1, comp2, comp3;
ProName asm_datums[3];
ProAssembly pasm;
ProSolid pcomp;
ProModelitem asm_datum;
ProSurface surf;
ProName sect;
int i_dtm;
ProXsec pxsec;
mdl = TkMdlRetrieve(m_sCompPath, prt);
comp1 = TkMdlRetrieve(m_sCompPath, prt2);
pasm = (ProAssembly)mdl;
ProStringToWstring(asm_datums[2], "ASM_RIGHT");
ProStringToWstring(sect, "A");
assy_err = ProModelitemByNameInit(pasm, PRO_SURFACE,
asm_datums[2], &asm_datum);
assy_err = ProGeomitemToSurface((ProGeomitem*)&asm_datum,
&surf);
assy_err = ProSurfaceIdGet(surf, &i_dtm);
ProXsecPlanarCreate((ProSolid)mdl, sect, i_dtm,
PRO_XSECTYPE_MODEL, NULL, &pxsec);
Best regards,
Stephen Gumbas
Enser Corp.
(856) 829-5522 ext 56
