XToolkitObsoleteFunc with C++ otk in Creo 9.0.0.0 for pfcComponentFeat::GetModelDescr()
PAULR_UK
6-Contributor
I am attempting to get a c++ otk creo adding to work with Creo 9.0.0.0. I have the plugin working in 8.0.0.0 and 8.0.3.0 with the following code:
[ I should note that I have used the 8.0.0.0 otk libs to build against as that was the original target version - my issue may just be that I have to build against 9.0.0.0 protk and otk libraries - I will try that if that is confirmed to be the case]
pfcFeature_ptr childFp = childFeatures->get(i);
pfcComponentFeat_ptr compPtr = pfcComponentFeat::cast(childFp);
pfcModelDescriptor_ptr mdlPartInstDesc = compPtr->GetModelDescr(); <== exception thrown here
and ultimately I need to obtain the child model using the Model Descriptor and the current session
pfcModel_ptr childMdl = currentSession->RetrieveModel(mdlPartInstDesc);
However I get an exception pfcExceptions::XToolkitObsoleteFunc
Message : "pfcExceptions::XToolkitObsoleteFunc"
MethodName : "pfcModel::Model::Descr<get>"
ToolkitFunctionName : "ProMdlDataGet"
thrown when I call compPtr->GetModelDescr(). I do not see this function listed as obsolete in /PTC/Creo 9.0.0.0/Common Files/otk_cpp_doc/Otk_Cxx_RelNotes.pdf
Hi Paul
ProMdlDataGet is TK and it is obsolete. So it gets automatically replaced by using the new 9.0 sources.
So yes, you need to get the Creo 9.0 sources and build against them.
Br,
Eike
Hi Paul
Br,
Eike
Thanks Eike for your prompt reply
