amount of holes by length of profile with parameters
BA_10140001
I have a U profile that I control with parameters.
There are 2 holes in this profile, if the length is 1000mm. If the profile is bigger than 1000mm, then I want to have 4 or more holes in the profile.
Can this be set parametrically with Creo 7?
How do I do this ?
Thanks in advance for your suggestions!
tbraxton
22-Sapphire I
(To:BA_10140001)
If you are asking how to vary the number of holes in a part based on the length of the part, then you can do it with conditional statements in the relations. Put a conditional test in the relations for the length and then adjust the number of holes as required.
The pseudo code would look something like this.
If length <= X
then # of holes =H1
else
   If length >X
   then # of holes = Y
endif
See this for reference:
https://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/fundamentals/fundamentals/fund_seven_sub/Conditional_Statements_in_Relations.html
Another option is to use Pro/Program which can pause for user interaction if desired to deal with this.
Involute Development, LLC
Consulting Engineers
tbraxton
22-Sapphire I
(To:BA_10140001)
If length <= X
then # of holes =H1
else
   If length >X
   then # of holes = Y
endif
unzip uploaded file and open example.prt. Then change part length from 200 to 300 (for example) and regenerate. Then investigate relations.
Martin Hanák
