I am getting XToolkitGeneralError at times while starting ProEngineer in asynchronous mode through a J-Link program. When restarted the process, it is connecting to ProEngineer and working fine.
I am hoping the below change of code will show some useful result.
Are there any possible issues with this change?
Did you find solution to this problem.? If yes can you please post the solution.
Nikhil I am also facing the same problem after changing java JDK and JRE. Earlier i was able to connect fine.
