Hello everyone,
How can I remove the "Expand All" command from the navigation trees?
It’s an extremely annoying icon.
Thank you in advance for your help.
Pavel
Model tree info from the support pages:
Seems to indicate that you can't remove such things from the interface.
Unless someone else knows a method, which is unlikely.
I guess the display image is saved on disc, you can try to replace the image by a 1x1 transparent image, if gif or png. This will make it difficult to hit 😵💫or a red point only.
If Creo is blaming about the size, I don’t believe that, but you can try to completely remove the image (here you may get a default one), or just a blank image with the same size.
