to whom it may concern...
Hi there,
I recently installed Creo Parametric 10.0.8.0.
As it turned out, the debug console, you can activate by adding "set CEF_DEBUG_PORT=9222" to your start command is broken in the latest release of Creo 10.
Usually, You get debug information displayed, when You open "http://localhost:9222/" on the computer running Creo Parametric.
In 10.0.8.0 that address just shows a blank page (NO "This site can’t be reached" error !).
In 10.0.7.0 everything works as intended.
I tested this on several machines. Also tried to install both versions parallel.
But to get the console working again, I had to uninstall Creo completely and reinstall 10.0.7.0 again.
I changed to using chrome://inspect in July of 2024 instead of using http://localhost:NNNN.
Hi @Mat,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
