dtl files
ptc-120027
dtl files
I'm not really sure I have a full understanding of dtl files. I would like that drawings use the same one, unless otherwise needed. I set up in config.pro "drawing_setup_file C:\projects\prodetail.dtl" but does not seem to make a difference. Am I missing something?
Also if you modify the dtl file does that become "Active Drawing.dtl" in which case that is part of the drawing so to speak, and remains that way regarless of standard one set up previously.
Thanks for you help.
Eric Fleming
Engineering Technician
ITT Corporation
Residential & Commercial Water
2881 East Bayard Street
Seneca Falls, NY 13148
Phone: 315-568-4543
Fax: 315-568-4507
-<">mailto:->
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
