no response when i click home -> utilities -> axuiliary application . and button is grey. I'm sure I followed the documentation.
Check in
\Program Files (x86)\Common Files\PTC\Creo\Platform or
\Program Files\Common Files\PTC\Creo\Platform
Or check in Control Panel > Program and Features if it was installed.
Domen
What auxiliary application is installed?
emmm, i'm hasn't auxiliary application is installed.
i just want open the auxiliary application windows, and add the test jlink-project.
the auxiliary application button is grey. i can't click.
Check if Creoagent is installed. If not reinstall it.
i have install that all i can installed
hi, i'm not find Creoagent. is it in creo parametric??
Check in
Domen
yss. i find it, and has been installed
Which build of Creo 2.0 do you have?
M130 student edition.
Now I might not need creo2.0.But thanks anyway.
It would not surprise me if they didn't allow auxiliary applications for the student edition. Previously they did not allow recording of trail files to prevent using the student edition from being used to reuse student efforts.
