Team,
I Would like to Create a ordinate dimensions automatically, after finding the flat view in drawing...
1. code need to find out the Flat View is present or not
2. need to create automatic ordinate dimensions for the view
Please help me to solve my problem
platform: CREO 4.0 M140 / toolkit C++
a general answer to a general question...
In order to create a drawing ordinate dimension one would need to create a drawing linear dimension with ProDrawingDimensionCreate(...) and to convert that dimension to the ordinate one with ProDrawingOrdbaselineCreate(...) and ProDrawingDimToOrdinate(...)
The generic approach for finding a specific drawing view is to use ProDrawingViewVisit(...) function and to query each visited view for app specified data, whatever that data might be. When app's data would match view's data the visiting should stop...
HIH
Hi team,
I have used the sample code (Article - CS277961 - The sample code of API ProDrawingDimensionCreate() (ptc.com)) to create the Dimension for the drawing...
the dimensions are creating for all the views, but i need the dimensions for the only flat view once views are filtered.
even after filtering the specific view ,code is taking the other attachements and creating the dimension,
is there any other API that is more specific with drawing view instead of Drawing completely?
correct the line of where iam missing for specific flat view attachments.
(fyr)myCode:
ProError CheckFlatView(ProDrawing Drawing, ProAppData data) {
ProError status;
ProViewType Type;
ProName viewName;
ProView *views = NULL;
int m;
int n_views = 0;
char cViewName[99];
ProViewType* General;
ProSolid solid;
status = ProDrawingViewsCollect(Drawing, &views);
if (status == PRO_TK_NO_ERROR){
status = ProArraySizeGet(views, &n_views);
for (int j = 0; j <= n_views; ++j){
status= ProDrawingViewSolidGet(Drawing, views[j], &solid);
char cMdlName[99];
ProName MdlName;
status = ProMdlMdlnameGet(solid, MdlName);
ProWstringToString(cMdlName, MdlName);
string sModelName = cMdlName;
// if (cMdlName != nullptr && "FLAT" != nullptr && strstr( "FLAT", cMdlName) != 0){
char *p =strstr(cMdlName,"FLAT");
if (p) {
// if (strstr(cMdlName, "FLAT") == NULL) {
string sMessage = "\n View is flat:";
Log::PrintMessage("DrawingInformation.txt", sMessage);
ProModelitem csys_item_1;
status = ProModelitemInit((ProMdl)solid, 68, PRO_CSYS, &csys_item_1); //68 is item id
status = ProDrawingViewInit((ProDrawing)Drawing,1, &views[j]); //8 is drawing view id
ProSelection* p_selection;
status = ProArrayAlloc(2, sizeof(ProSelection), 1, (ProArray*)&p_selection);
status = ProSelectionAlloc(NULL, &csys_item_1, &p_selection[0]);
ProModelitem csys_item_2;
status = ProModelitemInit((ProMdl)solid, 8, PRO_CSYS, &csys_item_2); //8 is item id
status = ProSelectionAlloc(NULL, &csys_item_2, &p_selection[1]);
status = ProSelectionViewSet((ProView)views, &p_selection[1]);
ProDimSense *sense_arr;
status = ProArrayAlloc(2, sizeof(ProDimSense), 1, (ProArray*)&sense_arr);
sense_arr[0].type = PRO_DIM_SNS_TYP_PNT;
sense_arr[0].sense = 3;
sense_arr[0].angle_sense.is_first = PRO_B_FALSE;
sense_arr[0].angle_sense.pic_vec_dir = PRO_B_FALSE;
sense_arr[0].angle_sense.should_flip = PRO_B_FALSE;
sense_arr[0].orient_hint = PRO_DIM_ORNT_NONE;
sense_arr[1].type = PRO_DIM_SNS_TYP_PNT;
sense_arr[1].sense = 3;
sense_arr[1].angle_sense.is_first = PRO_B_FALSE;
sense_arr[1].angle_sense.pic_vec_dir = PRO_B_FALSE;
sense_arr[1].angle_sense.should_flip = PRO_B_FALSE;
sense_arr[1].orient_hint = PRO_DIM_ORNT_NONE;
ProMouseButton btn;
ProVector loc, csys_3dpos;
if (ProMousePickGet(PRO_ANY_BUTTON, &btn, loc) != PRO_TK_NO_ERROR)
return PRO_TK_GENERAL_ERROR;
ProDimension dimension, vbase_dim;
ProDimAttachment *attachment_arr;
status = ProArrayAlloc(2, sizeof(ProDimAttachment), 1, (ProArray*)&attachment_arr);
status = ProSelectionCopy(p_selection[0], attachment_arr[0]);
status = ProSelectionCopy(p_selection[1], attachment_arr[1]);
status = ProDrawingDimensionCreate((ProDrawing)Drawing, attachment_arr, sense_arr, PRO_DIM_ORNT_VERT, loc, PRO_B_TRUE, &dimension);
status = ProSelectionViewGet(p_selection[0], &views[j]);
status = ProAnnotationShow(&dimension, NULL, views[j]);
status = ProArrayFree((ProArray*)&sense_arr);
else {
string sMessage = "\n wrong call:";
return status;
Thanks InAdvance
Abdul Aziz
to OP: you would need to collect views relevant to your task with ProDrawingViewVisit(...) prior to running dimensioning code...
on a side note: the following line advances the index past the last element of the array...
Yes, i have used that API to visit views (status = ProDrawingViewVisit((ProDrawing)Drawing, ViewVisit, (ProViewFilterAction)CheckFlatView, NULL);)
From that (ProVIewFilterAction)CheckFlatView..
and i have changed the loop for n_views to ( for (int j=0; j<n_views; j++)).... Please help me to solve this problem
Thanks InAdvance
Abdul Aziz
HI Team,
I am getting dimension From the annotations dispaly method. now i want to know how to convert that linear dimesions into ordinate dimensions. What is the manual approach for this to achieve?
linear dimensions are not taking the single base line if iam trying to toggle it ordinate manually.. can you please this as a concern.
HI Team,
I am getting standard dimension from the annotations show () method. now i want to know how to convert those standard dimensions into ordinate dimensions. What is the manual approach for this to achieve?
standard dimensions are not taking the single base line if Iam trying to toggle it ordinate manually. can you please take this as a concern.
the method you have suggested is not suitable for standard to ordinate dimensioning. may be suitable for linear to ordinate. advise me a best way to fit my requirement..
do not use model dimensions.
make drawing linear dimensions and convert them to ordinate.
if needs to be, model dimensions could be queried for attachments and positions and the acquired data could be used in making drawing dimensions.
make sure the config.pro option related to storing drawing dimensions in a drawing file was set to yes.
HIH
can i use the ProDimensionAutoOrdinateCreate() API instead of converting standard dimension into linear ,linear to ordinate?
Please let me know how to get the surface/regions from the view which is selected..
thanks InAdvance
Abdul Aziz
I would avoid using ProDimensionAutoOrdinateCreate(...)
The function takes an array of parallel surfaces and arbitrary decides what edges to be dimensioned... There is no way to define a 'dimensioning strategy' to pass to this function... Try to use its UI counterpart while in a drawing and you very likely would spend more time deleting and rearranging auto dimensions as you would spend making necessary dimensions one by one
