how to set the java exception site for windows local folder
  • March 6, 2017
  • 24943 views
how to add the folder "D:\Program Files\PTC\Creo 3.0\Common Files\protoolkit\" to Exception Site List in Java Control Panel?
java 1.8.x
windows 7 x64
internet explorer 11
on the Java web site, there are only exsamples for HTTP and HTTPS,
there is NOT any exsample for FILE protocol.
file:///D:\Program Files\PTC\Creo 3.0\Common Files\protoolkit\
file:///D:/Program Files/PTC/Creo 3.0/Common Files/protoolkit/
neither works
as a result , when i open the ProToolKit API , there comes the java security warning message.
Best answer by Eike_Hauptmann
We changed mostly to the non Java Version of the Helpfiles.
file:///<INSTALL_PATH>/Creo%203.0/M100/Common%20Files/protoolkit/protkdoc/manual0/loadToolkitDoc.html
So it's not that easy to make searches, but it works very well to find commands if you have an idea of the command name.
Br,
Eike
Here is an example of my Pro/TOOLKIT exceptions list.
You must use forward slashes in the path.  I see that you have that in one of your examples.  However, it seems you are missing an additional path/file.
file:///C:/PTC/PROE_WF5_M200/protoolkit/protkdoc/
xd_011-VisitorAuthor
thanks so much for your reply.
1, I notice that , there is no SPACE in you path. I guess that the SPACE in the path have some affect.
i tried replace the SPACE with '%20', and i will try to copy the doc files to a folder with no SPACE.
2, there are 3 '/' after "file", is it right?
3, do i need to add both 2 locations in your picture to the Exception Site List?
file:///C:/PTC/PROE_WF5_M200/protoolkit/protkdoc/NSCPTestSwing.html
4, i encountered a policy problem, i will upload the screen snap later.
