how to use specified font when extrude words
WP_14104464
3-Newcomer
I am ready to engrave some words on a surface using extrude function. The code list below, but seems the specified font did not  work. I checked the feature created by this function, the font is still font3D. How can I use other font?
double height = 10.0;
pfcPoint2D_ptr firstCorner = wfcCreatePoint2D(-25.00, -25.00);
double length = 48.764;
pfcPoint2D_ptr secondCorner = wfcCreatePoint2D(-25.00 + length, -25.00 + height);
wfcSectionEntityText_ptr text = wfcSectionEntityText::Create(firstCorner,secondCorner,content);
text->SetFontName("cgomg"); // use font cgomg
wfcSectionEntity_ptr textEntity = wfcSectionEntity::cast(text);
sketch->AddEntity(textEntity);
sketch->SetIntentManagerMode(true);
sketch->SetIntentManagerMode(false);
/* Redefining the feature */
extruFeat->RedefineFeature(0, extractedTree, featOpts, regenInstr);
tbraxton
(To:WP_14104464)
One possibility may be that the font is not stored in the proper location to be called. Creo stores TTF in a directory and not in models. Is the font you are referencing saved in the font directory and loaded?
https://support.ptc.com/help/creo_schematics/r9.0/en/index.html#page/schematics/install_guide/c_sysadmin_7.html
Involute Development, LLC
Consulting Engineers
Hello @WP_14104464
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Sorry for a long time delay.
In fact, the problem has been troubling me along.
I checked the support info below:
It seems Creo can use fonts provided by PTC,  and other ttf fonts with settings of pro_font_dir.
I tried several ways to solve the issue.
1, use CG Omega in the table, and switched the name like "cgomg", "CG Omega", or "ccgomg.ttf",  no works.
2, set pro_font_dir as C:\Windows\Fonts\, and then set  windows font name , like "simhei", no works either.
No progress yet.
