loadpoint location
abush
loadpoint location
Are there good reasons for installing PTC software at c:\ptc? Or is it
no big deal to install in c:\program files? Most companies seem to use
c:\ptc, but I can't find any documentation that actually recommends that.
AB
7 REPLIES 7
The space in c:\Program Files can cause problems.
Dave Sartori
Systems Project Leader
Global CAD/CAM Systems
PA Engineering
Kohler Company
444 Highland Drive
Kohler, WI 53044
It is not recommended to use path-names with blanks.
Hubert Stüken GmbH
Johannes Pietsch - Administration CAD
Tel.: 05751 - 702 - 244 , Fax: 05751 - 702 - 188
Mail: Johannes.Pietsch@stueken.de Web: www.stueken.de
unknown1
(To:abush)
Of course if the software was really Microsoft compliant, spaces in the file and folder names would not be an issue.
Wildfire is Windows Certified. This means a couple of things.
1. PTC has to support spaces on their folder structure and Wildfire does.
2. PTC must make the default location for the installation, "Program Files"
I believe most Administrators load Pro/E on c:\ptc out of habit. We could
not deal with spaces in the past. I personally like to have my
installation in c:\ptc to keep it apart from other installation on my
system. This makes my custom scripts easier to type up. I also avoid
spaces to make my scripts easier to write. Batch files don't like spaces
unless you use "Quote" marks to identify spaces in folder names.
Damián Castillo
CAD Administrator and Consultant
Hensley Industries
http://www.hensleyind.com
972-406-4788
Sartori Dave
<dave.sartori@koh <br="/> ler.com> To
Sent by: "PTC/USER System Management
bounce-sysmgt-144 Discussion"
-user <->
.org cc
Subject
10/25/2005 03:13 [sysmgt] RE: loadpoint location
PM
Please respond to
Sartori Dave
Dave Sartori
PA Engineering
Kohler Company
444 Highland Drive
Kohler, WI 53044
dgschaefer
(To:abush)
Actually, the companies I've worked for have both installed into the
'Program Files' folder since that became the default (2000i?  Rev 20?)
and have had no problems.  I initially thought that the space would be
an issue, but it has never been a problem.
Both companies were/are running Win 2K.
Doug Schaefer
LinkedIn
I have avoided spaces in paths for PTC products for a while,
particularly on Windows systems. I do not know how Wildfire has
improved but Pro/I 3.3 and Pro/E 2001 still have some behind the scenes
issues with spaces in one way or another. Why bother fighting it?
Even Microsoft Outlook and other applications have to be told something
special to make spaces work for various reasons, such as typing a URL or
UNC path in an e-mail. If you want a space in it, you have to surround
it in "<>" to make it work. As someone else mentioned, you have to put
paths in double quotes for other Windows programs and for command-line
stuff.
Here's another odd thing spaces can do to you. A while before I started
work here, IT changed user names to First Last (with the space). Now
users here can't launch an object directly into Pro/E from a Workspace
(Pro/E 2001 and Pro/I 3.3). Things are also set up here to create a
user's Pro/I local database using the same username format in the path.
That keeps any program from opening an object from within a Workspace.
By removing that space in the path, users who need to update Word or
Excel documents here can now do so directly in the Workspace and save
back to the WS. Even with this change, a space in the username still
prevents Pro/E from working though. Yes, users can launch an object
with any application they want directly from a WS except for Pro/E.
Spaces are always going to be a problem somewhere because a space is
frequently an indicator of a separation between a command and an
argument or option. PTC can't fix this any more than Microsoft can.
Spaces have been possible in Unix a lot longer than in Windows but in
that "world" spaces in paths are still avoided.
hollek
(To:abush)
Here's the best reason to avoid spaces in the path names for both
Intralink and Pro/E:
From TPI 129083
Steps To Troubleshoot Errors On Importing Into Or Exporting From A
Workspace In Pro/INTRALINK
Details Additional Information
Description
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
