mixed beam & solid analysis?
lylebeidler
Is it possible to use beams & solids together in Mechanica Wildfire 2.0?
I have frame rails connected by crossmembers which are structural
c-channels, and I'd like to approximate the crossmembers using beams, while
keeping the frame rails as solid elements. So I created datum points on the
frame rail parts, and used those datum points as the endpoints when creating
my beam idealizations. However, the run terminates with a fatal error,
saying the model is underconstrained. As soon as I take my beam elements
out, the model runs fine. What am I doing wrong, or is this something
Mechanica just can't do?
Thanks!
Lyle Beidler
MGS Incorporated
178 Muddy Creek Church Road
Denver PA 17517
Phone: 717-336-7528
Fax: 717-336-0514
<blocked::http: www.mgsincorporated.com="/> http://www.mgsincorporated.com
hi,
14 years later I have the exact same question.
I'd like to connect a beam (beam-element created with AFX) to a plate (solid model, see attatched picture).
The plate is fixed on a hole.
What is the right way to connect the beam to the solid model ? When I try to solve the simulation there is a fatal error.
Maik
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
