multax troubles
Newbie
multax troubles
Hi all -
I am having some issues with the post outputting A and C moves after a
tool change for mutli axis work. I specify the machine csys in the
operation and a seq. csys for positioning. My first seq. is a drill and
positions just fine, then for a toolchange, A goes down to 0, brings in
the next tool (endmill) and I run a volume milling seq, but the post
doesn't output the A and C move to get back to position.
I have the same seq. csys selected for the volume milling seq. and the
holemaking seq. If I insert A-90.C-100. at the end of line N26 all is
well, cuts where it is supposed to. However, all kinds of bad things
could happen if I didn't insert that text.
I can select 5 axis holemaking and pick holes in all different planes
and each orients correctly. It just seems when I put the 3 axis only
type seq. with 5 axis capable seq. is when it balks. I have the tool
change coords input under the machine codes:tool change section of the
post.
Any ideas?
Here's my G code:
O5
G0G54A0.C0.
(5)
G90G80G17G40G49G00
N1T4
N2M06
N3G00X0.Y0.Z0.
N4T6
G90G54G80G17G40
G54.3P1
N5S5457M03
N6M08
N7G01G93G43X.25Y-4.5588Z3.38F5.57H04A-90.C-100.
N8G05.1 Q1 R1
N9G81X.25Y-4.5588Z1.3075R1.98F300.A-90.C-100.
N10G80
N11G01G94Z3.38F75.
N12M09
G54.3P0
G05.1Q0
N14M05
N15G00
N16G53Z0.
N17G00
N18G53A0.
N19M01
N20T6
N21M06
N22G00X.25Y-4.5588Z0.
N23T7
G90G54G80G17G40
G54.3P1
N24S5600M03
N25M08
N26G01G43X-2.7968Y-4.6138Z3.38F75.H06
N27G05.1 Q1 R1
N28Z2.115
N29Z1.915F25.
N30X-2.7941Y-4.6226Z1.8812F47.
N31X-2.7906Y-4.631Z1.8682
N32X-2.7866Y-4.6389Z1.8588
continues on cutting...
