I am trying to run a simple app in async mode.
I have 64bit machine (Windows 7)
My JVM seems to be 64bit
>java -version
And I point my PATH to
proeWildfire 5.0\x86e_win64\lib
When I try to run my app - it fails on
System.loadLibrary("pfcasyncmt");
Throwing
Exception in thread "main" java.lang.UnsatisfiedLinkError: proeWildfire 5.0\x86e_win64\lib\pfcasyncmt.dll: Invalid access to memory location
Any ideas?
Bartek
The Path seems to be ok - Are you using the correct jar file (pfcasync.jar and not pfc.jar) ?
This is how I invoke the app
java -cp "C:\Program Files\proeWildfire 5.0\text\java\pfcasync.jar;[CUT]\workspace\JLinkSandbox\bin;[CUT]\workspace\JLinkSandbox\lib\log4j-1.2.16.jar;[CUT]\workspace\JLinkSandbox\simple-asynch\src\main\resources" jlink.SimpleAsynch
Hello
The problem is the spaces in the Pro/E path. You should not install Pro/E using spaces in the path. Move the install into a directory path without spaces, example C:\ptc\proewildfire5. This should fix the issue.
Why are you using log4j? I would use a JAR file to start the project.
An example start up batch file is displayed below. Note: it is for a 32 bit system due to the paths.
REM ****************************************
REM SET PRO/ENGINEER PATH
set PROE_DIR=C:\PTC\proeWildfire5
REM SET J-LINK APPLACATION PATH
set JLinkApp_DIR= C:\EclipseProjects\Workspaces\JLinkProject\jar
REM SETTING J-LINK CLASS PATHS
set PATH=%PROE_DIR%\i486_nt\lib;%PATH%
set PRO_COMM_MSG_EXE=%PROE_DIR%\i486_nt\obj\pro_comm_msg.exe
REM CALL J-LINK APPLICATION
java -cp %PROE_DIR%\text\java\pfcasync.jar;app.jar com.felco.exampleapp.MyAsyncApp
I do not think it i a "whitespace in a path" problem. If I change the name of the lib to load I get
Exception in thread "main" java.lang.UnsatisfiedLinkError: no pfasyncmt in java.library.path
So the runtime is able to loacte the DLL. I have reinstalled ProE just in case but the problem remains.
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Applications\ProE\x86e_win64\lib\pfcasyncmt.dll: Invalid access to memory location
Bartek
I had same issue...when I tried to run 64Bit ProE on 32Bit JVM....
may be this can hel u verifying JRE
I will give a bad suggestion
...since system is having hard time in finding the "pfcasyncmt.dll".........
copy and paste it to the bin directory or to the class path...
and ![]()
forgive me if something goes bad....just delete the newly copied "pfcasyncmt.dll"
upgrade from M010 to M060 fixed the problem
M010 seemed to have a bug
