pfcasyncmt.dll: Invalid access to memory location
BartoszDobrzele
I am trying to run a simple app in async mode.
I have 64bit machine (Windows 7)
>echo %PROCESSOR_ARCHITECTURE%
AMD64
My JVM seems to be 64bit
>java -version
And I point my PATH to
proeWildfire 5.0\x86e_win64\lib
When I try to run my app - it fails on
System.loadLibrary("pfcasyncmt");
Throwing
Exception in thread "main" java.lang.UnsatisfiedLinkError: proeWildfire 5.0\x86e_win64\lib\pfcasyncmt.dll: Invalid access to memory location
Any ideas?
Bartek
7 REPLIES 7
The Path seems to be ok - Are you using the correct jar file (pfcasync.jar and not pfc.jar) ?
This is how I invoke the app
java -cp "C:\Program Files\proeWildfire 5.0\text\java\pfcasync.jar;[CUT]\workspace\JLinkSandbox\bin;[CUT]\workspace\JLinkSandbox\lib\log4j-1.2.16.jar;[CUT]\workspace\JLinkSandbox\simple-asynch\src\main\resources" jlink.SimpleAsynch
Hello
The problem is the spaces in the Pro/E path. You should not install Pro/E using spaces in the path. Move the install into a directory path without spaces, example C:\ptc\proewildfire5. This should fix the issue.
Why are you using log4j? I would use a JAR file to start the project.
An example start up batch file is displayed below. Note: it is for a 32 bit system due to the paths.
REM ****************************************
REM SET PRO/ENGINEER PATH
set PROE_DIR=C:\PTC\proeWildfire5
REM SET J-LINK APPLACATION PATH
set JLinkApp_DIR= C:\EclipseProjects\Workspaces\JLinkProject\jar
REM SETTING J-LINK CLASS PATHS
set PATH=%PROE_DIR%\i486_nt\lib;%PATH%
set PRO_COMM_MSG_EXE=%PROE_DIR%\i486_nt\obj\pro_comm_msg.exe
REM CALL J-LINK APPLICATION
java -cp %PROE_DIR%\text\java\pfcasync.jar;app.jar com.felco.exampleapp.MyAsyncApp
I do not think it i a "whitespace in a path" problem. If I change the name of the lib to load I get
Exception in thread "main" java.lang.UnsatisfiedLinkError: no pfasyncmt in java.library.path
So the runtime is able to loacte the DLL. I have reinstalled ProE just in case but the problem remains.
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Applications\ProE\x86e_win64\lib\pfcasyncmt.dll: Invalid access to memory location
Bartek
I had same issue...when I tried to run 64Bit ProE on 32Bit JVM....
may be this can hel u verifying JRE
http://java.com/en/download/testjava.jsp
I will give a bad suggestion...since system is having hard time in finding the "pfcasyncmt.dll".........
copy and paste it to the bin directory or to the class path...
and forgive me if something goes bad....just delete the newly copied "pfcasyncmt.dll"
upgrade from M010 to M060 fixed the problem
M010 seemed to have a bug
